1963 dodge floor pan interchange?
k-ams
11:41 AM
wisconsin
I have a '63 dodge 330 needs floors from front firewall to trunk floor. So picked up a '65 coronet 4 dr for the floors etc. I was wondering if there is a difference in the floors between the 2? I know the rear leaf spring in different!
I do believe the front main floor and trunk floor are mostly the same. So is it the rear foot area over the axle part different?
Maybe just were they welded the rear front spring hangers on?
Thanks for any info.
All the pans are the same except the 63 rear foot well pan is longer than the 65. 63-4 Dodge had a longer wheel base than 62 and 65 Dodge and the difference is in the rear foot well pan. Front, under rear seat and trunk will work. You will need to find a 63-4 Dodge foot well pan as the 62-5 Plymouths had the shorter pan like the 62 and 65 Dodge.
Rear frames and springs are the same for all 62-5 for the most part..
^^^ That is absolutely correct. I found that out the hard way.
