1964 Plymouth aftermarket A/C install
64Bob
12:52 PM
Chicago, Illinois
Has anyone installed a aftermarket AC unit into a 1964 Sport Fury. If so what brand?
For the 66- rides, you can buy a package. For us -65 gents, you have to piece it together as a DIY. Thats what I'm doing, but not done yet. I rented an empty shell plus mount bracket from Restomod Air to make my own weld on mounts for the firewall mounting. Those are made, have the condenser/compressor/drier already, made provisions for the plumbing[ going between inner and outer fender on rh side]. Thats as far as I've gotten so far.
I installed Vintage Air in my 1964 Polara. As someone else already said, no one makes a kit for Early B-bodies, and you have to noodle it out yourself. The kits route the A/C and heater hoses out through the inspection hole in the passenger side inner fender, which I do not like. I figured out a way to keep everything inside the engine compartment. I took a lot of pictures and posted about my progress as I went. I can send you copies of my invoices with part numbers, if you want.
Click on Search Forums. Type in Vintage Air and then Dave6T4. You will find a bunch of posts, and you can sort through them.
