WTB 1966 1967 quarter window glass tracks and hardware - convertible
TommyBoyGTX
4:56 AM
Scottsdale
So as it turns out..... on this 67 Tommy Boy project the 1/4 window tracks and hardware were all missing. I have the glass channel, just missing all these other pieces. From everything I see and know this is all the pieces needed. Looking for a complete left and right hand side set. 66 and 67 should be the same.....I assume.
I put a complete tinted glass setup out of a 1966 Satellite into my 1967 R/T many years ago. I recall that there was a difference between the two years in how the glass attached to the risers. It works if everything is changed as a unit. '66 glass will not attach to '67 risers, and vice-versa.
Ok....just so we are talking the same things here are you saying the "risers" are these pieces here?
It's been about 35 years. Is that what the glass attaches to? If I remember correctly, the '66 glass is bonded into a metal piece that attaches to the mechanism. The '67 glass is deeper, with through holes in the bottom. It attaches to the mechanism with plastic pins.
Ok yes.....hardtop and convertible are for sure different.
moparmarks.....the photo you posted I assume is the hardtop 1/4 glass you are showing? Showing the difference between the two years?
Yep. H/T glass. Just showing the mounting difference.
Thanks for vindicating my old memory, moparmarks. '67 on the left.
