tqfastfish
I am selling a 1966 dodge coronet 2 door post. originally a 6 cyl. car. I have had this car for about 11 years. selling it to fund a drag car.
MOTOR:
pump gas
1966 440(426 clone)
bored .30
block was pressure tested ,maged,and decked with plates
brass frost plugs
stock steel crank, turned 10:10
stock rods maged, polished, re-sized and fitted with arp rod bolts
Keith black hyper tech pistons
10;1 compression
fully balanced
moly rings
double roller timing chain set
high pressure oil pump
new oil shaft and pickup
comp custom hyd. cam
483 lift 280 duration 233 at 50 114 lope
452 steel heads ported
machined seats and bowls clean pressure test and mag test
resurfaced heads
machined for spring cups and seals
relined and polished quench area
gasket match
flat mill 0.35 cc
comp 4700 cups
comp seals,locks,springs,retainers,lifters and push rods
new mopar rockers
a and a max wedge cross ram with linkage,factory air cleaners.
2 eddy. avs 550 carbs
mopar elc. distributor and ignition
magnum manifolds
tti 3 inch exhaust,flow master muffles
TRANSMISSION
727 trans
2500 tsr stall converter
deep aluminum pan
all new steels and Kevlar clutches
low first gear
regular pattern valve body
REAR
8 3/4 rear
742 case
3;23 gears
new posi unit
INTIERIOR
all new door panels and seat covers, headliner ,rug,dash pad ect
a100 van looking seats
aluminum a100 seat brackets
auto meter gauges and tach,radio delete plate
EXTERIOR
very nice white paint
some imperfections
max wedge scoop
new chrome mirrors, bumpers,door handles,trim ect.
perfect grille and trim
new trunk mat.
bf Goodrich 275s/60s/15s rears and 215s/70s/15s fronts all new
8 inch cop car wheels on rear and 5 inch steelies on the front
SUSPENSION
new front end kit from pst includes all new ball joints tie rods ect
kyb shocks in front
air shocks rear
new rear leafsprings and bushings
1972 mopar manual disc brake front setup
power steering
chassis dynoed at 341 hp and 385 tq witch is 427 hp and 482 tq at engine
appraised at 26,500 in 2011
when i built the car it had minor rust over rear wheel wells and that's it , everything else was super solid! this car is a very fun and unique driver. rare 2 door post sedan car max wedge clone makes it that much more fun and cool great for car shows and family cruising
please visit the walkaround of the car that covairwild featured in a video by searching covairwild and searching his channel for 426, ! http://www.youtube.com/watch?v=r-NsXD_wa0M:headbang:
any more info needed ,please inquire
$24,500 obo
MOTOR:
pump gas
1966 440(426 clone)
bored .30
brass frost plugs
10;1 compression
fully balanced
moly rings
resurfaced heads
gasket match
flat mill 0.35 cc
comp 4700 cups
new mopar rockers
magnum manifolds
TRANSMISSION
727 trans
deep aluminum pan
low first gear
REAR
8 3/4 rear
742 case
3;23 gears
new posi unit
INTIERIOR
EXTERIOR
some imperfections
max wedge scoop
new trunk mat.
SUSPENSION
kyb shocks in front
air shocks rear
power steering
$24,500 obo
