j-c-c-62
I think "sleeving" is overrated, I am a believer in the largest cross section the installer can accept, which is rather limited if one is not OK with cutting the floor pan. Maybe a thickening plate where the fronts weld in? So, if cutting is not in the cards, I'd prefer at least a .120" wall, as weight in a wagon is not normally a great negative for street use, and the added weight is all well below center of gravity. If you ever get in a minor Tee bone accident, you will be in full agreement especially if you add a couple of ties to the rocker panels.SFC is one of the to do for sure upgrades. Will keep them simple. 2"x.090 or so material and just simple angle cuts on the rear and squared off with a rectangle piece to on the front. Not going to sleeve them into the existing rails like I've done on the 65, plus no 2x4 rectangle.
