1968 Charger Grille
Rob68Charger
12:34 PM
UT
WTB 1968 Charger grille assembly. I need the entire setup with headlights, doors, vacuum system, brackets, trim, etc.
Thanks
Front grill assembly
Have you found one yet? I may have one or can tell you were to get one completely redone for about 2k.
PM sent. My budget is under $1000. I'm looking for a driver quality grille that I can restore myself.
Check ebay
There is one on ebay right now that looks to be a good one that was well within your budget. I saw it the other day so I am not sure if it is still there. They are getting goofy money for these things. I will chew on if I will sell my assemebly and let you know. I was saving it for the next project but may do a 70 Charger next. I will probably want around $1200 for the works as I had to pay like $400 for a perfect center section alone. Let me know if you spot the one I saw.
Thanks, I did see that one. He's listed it a few times and I've bid on it before. I talked to him recently and unfortunately his reserve is much higher than the final price it gets every time he lists it...
How does yours compare to his as far as condition of the grille?
