FOR SALE 1968 coronet 440 sedan
What shape is the trunk floor valley pan in & the rear window channel ?...I need about 2 " of it...
Tr
Trunk floor is shot. Rear window channel should be very nice. Get me an idea of how much you need and where exactly. I’ll get some pics.
Passenger side about halfway up?
I was wondering if you have the rear spring shackles and what condition they are in. Price? Pics?
Looking for EC like the one in the photo, not scale pitted rust or worn pins, ones that will clean up to be nice.
Need a complete pair with original nuts. 3 1/2” pin center to pin center/ 2 7/8” between the side plates. 1/2” diameter pins.
Thanks!
Kevin
Thanks!
Kevin
They are on the car. Ill look next time i get to work on it
68_661charger. Front left frame rail. Very used. No pitting. I hit anything that looked very rust with hand wire brush.
Thanks!
Kevin
Got those shackles off. They’re awfully pitted up. I don’t think they’re what your after.
Not sure if you are keeping door handles with the doors, but I need the vertical rod, and any retaining hardware, that runs inside the door from the outside handle down to the latching mechanism. If you would rather not sell such little pieces I would be interested in the outer handle, that rod, and the latching mechanism. Both sides. I need it for a two door if it matters. Thanks
Not sure if 2door linkage is the same 4door. I’d sell just linkage though.
I think I found what I needed but haven't been able to confirm it yet. Thank you.
Sides look pretty good
Here are the bolts I need......P.O's had car disassembled & n boxes lucked out n found the L shaped channel bracket but could not find the bolts for the driver side window channels that hold it to the door, found the nut tho...yeah!...I also need the black plastic seat belt coil spring cover...dropped mine n well you know what happens then...ugh
