JimKueneman
The right side I used a rubber mallet and ended up putting small dings in it and pissed me off. I then thought about the the churchkey I used to get them off. There is nothing really special once you start doing it you will see. Get the upper edge pushed all the way in then try to roll the lower edge over the the drip rail. I just used the churchkey and hooked the upper edge and instead of using the "claw" on the key to pull the trim lip off the rail I used the "claw" on the upper edge and used it as a pivot point, Removing I pulled on the "claw", installing I pushed in on the "claw". I pushed the tool in and rotated down as to pivot on the "claw" end of the key and roll and push the bottom edge down and around the drip rail lower edge. Once you start it will be obvious. It is just how were you put the pressure on the churchkey
