FOR SALE 1969 Dodge Charger Hemi
pnora
4:08 PM
Ishpeming, Mi.
Feedback: +7 / =0 / -0
Decided to put my recently finished Charger up for sale. Please respond if you have the funds available. I will respond to all messages and discuss any questions. Car has not been out this year so these photos are from last summer. The tail stripe was added after the pictures.
1969 Hemi Charger.
Not an original Hemi car.
528 Hemi.
Runs on premium pump gas.
Dynoed at 642 HP and 650 TQ.
New MP Iron Block and heads.
Stage 2 head porting.
Indy roller rockers.
New rocker shafts and stands.
Custom push rods.
New oil pump.
New oil pan and sump screen.
Comp Cam flat tappet hydraulic.
Mopar performance single carb. aluminum intake.
Polished Indy aluminum valve covers with breathers.
TTI ceramic coated headers
TTI 3 inch h-pipe exhaust.
Bungs welded in collectors for O-2 sensors.
Pro Systems carburator.
Carter HP mechanical pump with fuel guage.
Mopar performance air cleaner.
New fuel tank, sender, lines.
Fuel gauge calibrated.
Mancini ready to run distributor.
MSD coil
Moroso custom wires
Custom serpentine belt drive.
Aluminum water pump and housing.
125 Amp one wire alternator
Mini starter.
Cold case radiator and fans.
Custom polished ss recovery bottle.
All new radiator and heater hoses.
Clasic auto air system.
Firm feel stage 2 gear box.
New power steering pump and hoses.
Complete front suspension rebuild all Moog.
Offset upper control are bushings for better caster adjustment.
Firm feel solid tube tie rod adjusters.
Original Hemi K-frame and engine brackets and mounts.
K-Frame blasted and powder coated.
All suspension parts blasted and powder coated.
Firm Feel HD torsion bars
New front shocks.
Precision steel drive shaft 1350 joints.
TKO 600 5 speed .64 OD.
Complete 5 speed conversion kit from Keisler.
Sachs clutch rated for 700 HP.
Clutch and brake pedals, mount, braces all restored.
All new pedals and pads.
Strange Dana 60, Locker 3.73, gears.
Ford SVO rear disc brakes with park brake.
Wilwood front discs.
All new brake lines and hoses.
New master cylinder and proportioning valve.
Torque thrust 2 wheels.
BFG tires
New rear springs.
New rear shocks.
All new wiring front to rear.
New AMD front and rear bumpers.
All bumper brackets blasted and powdercoated.
All new tinted glass.
All new cat whiskers.
New vinyl top.
All stainless trim professionaly restored and polished.
New remote control mirror.
All new name plates/emblems.
All new locks and keys.
Restored fuel fill tube.
All new vent hoses.
New fuel fill cap and door with bezel.
New trunk mat.
Jack and hardware restored and powder coated.
New upper and lower door panels.
New carpet.
New under carpet sound deadener pad.
New sill plates and extensions.
New outer and inner door handles.
All seat frames blasted and powdercoated.
Rear seat professionaly restored with new legendary covers.
Front seats professionaly restored with new legendary covers.
New front headrests with all new hardware.
All seat hinge covers and knobs are new.
All new seat belts.
All console plates and hardware is new.
New shift boots.
Factory AM-FM radio.
New antenna.
New front and rear speakers with fader.
Factory cluster with tachometer professionally restored.
New speedometer cable.
Speedomer calibrated correctly within 2 mph by radar.
Steering column restored.
New turnsignal switch.
New woodgrain wheel.
Dash frame blasted and power coated.
New dash pad.
New A-pillars.
New visors.
New headliner with insulation.
New back seat divider panel with sound deadener pad.
New rear shelf with sound deadener pad.
New inside rear window trim.
New window cranks.
All internal door and window hardware restored.
All new weatherstriping.
Restored wiper motor.
All wiper linkage restored, Bushings replaced.
New washer bottle, pump, hoses nozzels.
Grille professionally restored.
Grille frame blasted and powercoated.
All new grille trim and hardware.
Electronic headlamp door openers.
Body completely striped, soda and other media to a bare shell.
Fenders, doors, hood and trunk done the same.
New American made factory quarters. Not from China.
New trunk floor.
New trunk extensions.
New driver front floor pan.
Rest was normal metal finish with zero rust.
Welded in frame connectors.
Added Hemi rear torque boxes,rear shackle and pinion floor reinforcements.
Car was a Colorado car barn stored since 1990.
Overall a very clean car.
Origialy a base model 383, automatic, 8 3/4 rear.
Completely painted inside and out B5 Blue.
Outside completely done base coat clear coat B5 Blue.
Custom Matte black 528/HEMI Tail stripe.
The underside is as clean as the outside.
Front end computer aligned with print out.
Have build sheet and fender tag. All body numbers match.
200 miles since completed.
I am getting older and have lost interest, only reason for selling.
125,000.00 Car sold as is where is. No warranties expressed or implied. Clear title in my name. All funds must clear before the car moves. Inspections welcome. Will help load. No shipping on my end. Buyer needs to supply shipper.
100_2485.JPG 100_2480 (2).JPG 100_2490.JPG 100_2478.JPG 236058062_230881515471407_3119221795875582498_n.jpg 100_2483.JPG 100_2495.JPG 100_2493.JPG
