SOLD 1970 Charger R/T, 4-speed
gkeanef
8:34 AM
Indianapolis
70 Charger R/T, U code, 4-speed, 500 C.I. Stroker by Indy Cylinder Head, matching transmission, original 3:54 dana, cluster by Instrument Specialities, Legendary interior, TTI ceramic 2" headers and 3" pipes, Gear Vendors OD, Original EV2, triple white, R22. 1,100 miles on restoration. Located in Indianapolis area. $80,000.
Technically, "Triple White" would include the vehicle paint.
My bad then on the "triple". I was describing the white top, interior, and stripe. The engine in not matching numbers. The transmission is matching, and the dana is the original. The engine is based on a '74 440 HP block and was built by Indy Cylinder Head.
Is it possible to post a picture of the fender tag? Is there a build sheet? Do all vin #'s match on the trunk gutter, rad support, door decal, dash, fender tag, etc...?
.......... Thanks
There was no fender tag, build sheet, or door tag when I got the car. I had a reproduction fender tag made based on going over the car thoroughly to establish codes. I have photos of the research. I also had a door tag reproduced. The dash tag was in place, and it matches all of the body numbers. It also matches the 18 spline transmission. The Dana was the original and all of the dates and numbers are correct. I also have the original driveshaft with correct numbers. I can provide pictures of anything that you'd like to see. Thanks for the interest. Dave
