1970 dodge charger drip rail
Aussieguysyd
9:22 PM
Sydney Australia
Good evening all.
My charger is in restoration , and have removed the side roof drip rails on the roof . I have a new pair to re install , but having an issue in trying to locate the front drip rails that run down the front window frame ?
Can anyone steer me in the right direction
Much appreciated
Aussie .....
Since the A pillars are essentially the same on all 2 door hardtop 1966-70 B body cars, I'd say the drip rail trim sections should be the same across the entire line of Coronet, Belvedere, Charger and GTX models. You could probably use 4 door versions by cutting them down since the roofs are taller and the A pillars are longer on the 4 door cars.
Good evening all.
Much appreciated
Aussie .....
If you have lost the parts, I suggest you place an advert here .....someone will have a set to sell.... -------> WANTED - Mopar Parts and Cars - WTB
You are not permitted to advertise in the General or Technical forums.
Much appreciated Kern Dog :thumbsup:
