19bee70
Yep....just a 2 car garage. The trick to getting the engine in from the bottom was to sit the K frame with the engine on it, on a 4 wheel appliance dolly. HF for 20.00. Bolt the trans on and support it with another dolly. To lift the car, I used my cherry picker and lifted the car with eye bolts thru the shock towers with a V shaped chain. Slid the engine under and lowered the car down, guiding the engine to the center. The frame bolts went right in and I still had about 6 inches before the frame rails touched the floor so I was all clear. Jack the tail shaft of the trans a little to get it high enough to bolt the cross member in and you're done. Give me a call if you want to chat. My name is Mike. I can get you my number thru a PM.
