WTB 1970 water pump housing for 440
t.flatt
12:28 AM
North Dakota
Feedback: +3 / =0 / -0
Hello, I found a problem with the one I have so I need another one. Thermostat housing as well. Thanks for any help!
Travis
Do you need a date coded one? Or just one that exists the drivers side? I think 68-70 are the same…
One that exits on driver's side. A 70 date code would just be nice. I have a line on a pretty nice 68 one.
I have one, have to check the date code. Also, what heater hoses size ? And also the P/S pump side mounting stub size ? There's differences.
So 68/69.... slightly different from 70/71.... Different size pipe thread for heater hose nipples. Just trying to help with an FYI. 68 and 9 will work no problem. But then you have to heater two different thread size on end fitting which mega parts USA sells. Hope this helps... If these other guys don't come through I can look Wednesday. I may have one
Really, the power steering mount differs? That is why mine doesn't work. The housing measures 2 1/4" and there is 2 3/4" between my power steering brackets. I want to use the 2 different heater hose sizes for 1970. I have the heater hose nipples to make it work either way. I'm not hung up on the date code but 1970 would be nice.
Thank you! I thought these housings were the same for that 3-4 year run. I have the nipples to work either way. My power steering brackets have 2 3/4" between them. I plan on running 2 sizes of heater hose.
I have one on the way. Thanks to everyone for responding and helping out! You're awesome!
