1971 383 carb
paul1969cars
7:22 AM
new york
Hi
Does anyone know the correct model carter carb for 1971 383 4 spd cuda
There is also a #R6191 listed w/o fresh air hood. No notes why the different carb. California possibly?
This is from the 1971 Maintenance Manual
HOLLEY Model 4160 Series 4-Barrel Carburetor.
383 Manual trans. HOLLEY R-6191A what they call HEATED AIR.
383 Manual trans. HOLLEY R-6193A what they call FRESH AIR.
Hope it helps you out.
4160 model R4667 without fresh air hood. R4734 with fresh air hood.
Toolmanmike.
Not to stir up a hornets nest here, but where did you find those carburetor numbers for a 1971 383 4 speed car.
Just for me to know, where they were from.
Thank's.
1971
383 manual - E & B-body
orange HP engine
---------- Holley R4667A ---------- part number 3512 848 on b'cast 48
383 manual - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4734A ---------- part number 3512 849 on b'cast 49
***** some sources show the following manual trans carbs with the same part numbers *****
orange HP engine
---------- Holley R6191A ---------- part number 3512 848 on b'cast 48
orange HP engine
---------- Holley R6193A ---------- part number 3512 849 on b'cast 49
383 automatic - C-body
blue engine
---------- Carter 6125S ---------- part number 3512 844 on b'cast 44
383 automatic - E & B-body
orange HP engine
---------- Holley R4668A ---------- part number 3512 830 on b'cast 30
383 automatic - E & B-body - with "fresh air" (N96).
orange HP engine
---------- Holley R4735A ---------- part number 3512 842 on b'cast 42
Toolmanmike.
Thank's.
Galen book
1971
orange HP engine
orange HP engine
orange HP engine
orange HP engine
blue engine
orange HP engine
orange HP engine
Would you have info for 1970 Holley Carb
My Carter reads K3 6125S
Carter Carburetor 6125S 1970 1971 Dodge Plymouth 383 HP Auto Transmission. It even has the neat little copper tag. I don't know what the cfm is.
K3 October 1973 - Over the counter
Came from the factory on 1971 C Body Non HP 383
630 CFM
Dealers replaced a lot of Holley carbs with the Carter 6125S on 1971 383 HP engines
I have one in the attic off my 1971 Superbee - Car left the factory with a Holley carb according to my factory broadcast sheet
1970
383 manual - E & B-body - with ECS (N95)
orange HP engine 335hp
---------- Holley R4217-A ---------- part number 3418 537 on b'cast 37
383 manual - E & B-body - w/o ECS
orange HP engine 335hp engine on b'cast 084 with A/C & 087 w/o A/C
---------- Holley R4367-A ---------- part number 3418 536 on b'cast 36
383 manual - E & B-body - w/o ECS & with "fresh air" (N96).
---------- Holley R4736-1A ---------- part number 3512 964 on b'cast 64
383 manual - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4738-1A ---------- part number 3512 974 on b'cast 74
383 automatic - E, C & B-body - w/o A/C & w/o ECS
blue engine 330hp
---------- Carter 4736S ---------- part number 3418 538 on b'cast 38
383 automatic - E, C & B-body - with A/C (H51) & w/o ECS
blue engine 330hp
---------- Carter 4732S ---------- part number 3418 540 on b'cast 40
383 automatic - E, C & B-body - with ECS (N95)
blue engine 330hp
---------- Carter 4734S ---------- part number 3418 541 on b'cast 41
383 automatic - E & B-body - w/o A/C & w/o ECS
orange HP engine 335hp engine on b'cast 088
---------- Holley R4368-A ---------- part number 3418 542 on b'cast 42
383 automatic - E & B-body - w/o A/C & with "fresh air" (N96).
---------- Holley R4737-1A ---------- part number 3512 965 on b'cast 65
383 automatic - E & B-body - with ECS (N95)
---------- Holley R4218-A ---------- part number 3418 543 on b'cast 43
383 automatic - E & B-body - with A/C (H51) & w/o ECS
orange HP engine 335hp engine on b'cast 089
---------- Holley R4369-A ---------- part number 3418 562 on b'cast 62
383 automatic - E & B-body - with ECS (N95) & with "fresh air" (N96).
---------- Holley R4739-1A ---------- part number 3512 975 on b'cast 75
So what's right for my '71 Charger 500 383 hp AT? When you say fresh air I'm guessing that means some kind of hood air intake
630 CFM
Yes the Dealers replaced them because those Holley carbs originally came with cork gaskets that would shrink and start to leak fuel.
My experience many years ago. Ford products with 4 barrels and Holley were prone to having a backfire causing a fire under the hood. An acquaintance with a 59 Sunliner 361 4 barrel convertible burnt his sheepskin coat putting the fire out.
