This Wix is the big boy that adds 1 quart of oil capacity. I just changed the oil yesterday. The creased cardboard and slip the filter out by the splash guard and it is a easy job.
I change the oil AND filter every 3000 miles and have done so for the last 56 years and I have never had an issue getting the filter out of my '68 GTX. Messy, yes but not impossible.
I do it from under the car simply lying on a creeper with the front end either on jack stands or on a set of ramps. I have to slide it around a bit but it drops out every time.
I usually just remove it from the engine then let it rest on the sway bar and drain before manipulating it out.
I ALWAYS use the long filters and have been using the 51515 Wix for a couple of decades now.
