73-4 Charger Driver side Door glass $35
73-74 B-Body A/C heater control. $25
71-72 B-Body Strato non A/C heater control. Tab in the back broke. I have the tap for easy fix. $25
71-72 charger Rear valance no cutouts $75
73-74 charger rear valance no cutouts need work $20
71-74 Charger rear side ash trays. $10 each
71-74 Charger ash trays (in dash) $10
71-74 B-Body Dash frame for A/C car $50
71-74 B-Body front speaker core.$10
4 bow for headliner $40
71-72 charger vapor canister with covers. This is the one in the wheel well. $50 complete
71 72 Charger Front disk spindles $100 pair
71-72 charger drum type spindles with drums $75 pair
71-72 charger manual master $25
71 72 charger prop valve drum type $35.
I have body bolts & miscellaneous clips for 71-4 B-bodies
71-74 B-body door hinges good cores $40
71-72 B-body hood hinges good cores $40
1974 B-body 440 dual snorkel air cleaner real nice shape. $150
71-74 B-Body dash pad cores $25 each
71-74 B-body AM radio nice with knobs and bracket. $75
Cuda AM radio has cut wire came out of a 1974 $50
71-74 B-body lower windshield corner chrome pieces $25 pair
440 water pump housing ( 2 left sides and 1 right side) $25 each
Auto gage RPM $20
SW RPM gauge NOS $100
Big Block 4x4 truck headers $75
1972 charger SE ONLY drip rail moldings $40 pair
1972 charger SE ONLY drip rail moldings real nice $100 pair
1972 charger SE ONLY ¼ belt moldings $40 pair
71-72 charger NON SE belt moldings set doors & ¼’s. r/s ¼ has a pen ding $40 pair
71 charger owner’s manual used $10
71=74 Charger 150 mph clusters $200
72 charger left side manual no cable mirror $25
72 charger power disk booster $40
71-72 charger L/S & R/S two piece rear upper inside fender brackets $25 each or $40 pair
10” rear drum brake levers all 4 with hardware $25
71-2 b-body complete 2 speed wiper motor with trans linkage. $100(I don’t know if 73-74 are the same)
71-4 b-body wiper arms $40 pair
71-74 b-body wiper trans $75 I have one set apart for $50
Cragar SS center caps with the washer and screw. (Not the spinner type)
71-74 B-Body column shift collor $10
71-74 b-body column base.This is the part that bolt to the floor. $10
Koni rear sway bar new in box. $150
71-74 b-body three spoke horn pad. one Black and one tan and one DODGE center. $25 each
71-74 Charger 3 spoke black steering wheel nice. $100
71-72 Charger Blue ¼ ext.one stud on top of the left side broken. $30 pair
73-74 Charger red ¼ ext. good studs.$40 pair
71-72 Charger left side ¼ ext. Green 2 studs broken $5
71-72 Charger right side ¼ ext. Green Mint $25
75-79 Cordoba hood ornament NOS in box .$100
75-79 Cordoba L/S rallye mirror chrome.some pits $25
71-74 Charger L/S rear chrome NOS outline $165.
71-74 Charger left rear chrome outline. Some pits, driver quality $25 I also have two that need to be rechromed for $10 each Cores.
73-74 Charger SE right front filler. This is the piece that is between the fender & bumper.Needs to be painted and the top corner broke off $25obo
1970 RR/Satellite right rear ¼ ext. $25
Ramcharger L/S R/S taillight harness with bulbs mint $50
Ramcharger grill came off a 1989 $50
Ramcharger taillights $50 pair
71-74 B-body 2 speed wiper motor $25
71-74 Charger driver side valance marker light real nice $50
71-74 Charger trunk latch $25
71-74 Charger bumper guards these mount inside the front fenders. $25 pair
727 small block inspection cover $50
NOS Wagner wheel cylinders #FE-54398 $25 pair
71-74 Charger hood latch for cable type (No cable) $40
71-74 B-Body cowl screens $25 pair
71-74 B-Body dash map lights. Tell me what type you need. $10- $25 each
71-74 B-Body green sun visors real nice $50 pair
71-74 Glove box doors green & black (no locks) $20 each
71-74 glove box clear nice $25
71-74 Charger J-pinch moldings White & Green driver quality $10 pair & only one blue $5
71-74 Charger dome light. Just the base $5. With lens $10. Complete with wire $20
72-74 Charger SE pull strap caps $40 set of 4.
71-74 B-Body radio knobs complete with nuts & bracket that holds the radio. $30
71-74 B-Body glove box wire with button $20
71-74 B-Body non retractable rear seat belts. These are the 2 side ones. $20 pair
71-74 B-Body shoulder belt complete with clips/bolts. Black nice color not faded. $50
71-74 B-Body shoulder belt clips $5 each
71-74 B-Body standard dash light switch. $20
71-74 B-Body standard dash wiper switch $20
71-74 B-Body window crank handles $5 each
71-72 Charger fuel tank filler neck $40
I have other parts not listed yet so just ask.Thank you.
Would you have the wiring harness from the dash to the tail lights. All I really need is the rear window defrost and trunk light wiring, but would buy or trade for the whole harness. Let me know.
Regards,
Johnnie
Me again. See if you have the following also;
71-74 B-Body dash map lights. Tell me what type you need. $10- $25 each (The map light w/o fasten seat belt sign)
