SOLD 1972 Satellite Sebring Plus
RJS
10:08 AM
new jersey
Feedback: +17 / =0 / -0
1972 Satellite Sebring Plus 400 4bbl. automatic, comes with a 512 stroker and original engine. I will post the ebay ad since that has the most information
https://www.ebay.com/itm/1972-Plymo...f7709a5a:g:LVUAAOSwJTNbyJ2A:rk:1:pf:0&vxp=mtr
72 Satellite Sebring Plus 400 4BBL. "P code"
Running a 10.5 to 1 pump gas Aluminum Head 400 stroked to 512 cubic inches .
Original 400 included in sale.
Automatic 3.55 8 3/4
A/C completely restored and using R-12
Original radiator restored by Glen-ray, car always runs very cool.
Wiper motor, blower motor were restored by Bill Meerholz
Restored correct master cylinder and original booster redone by Booster Dewey.
Has correct Yellow cap Group 24 battery in it now.
Date coded wires, hoses voltage regulator etc..
Power Windows AM-FM from Retro Radio with a bluetooth plug hidden in ashtray.
4000 miles since restore on complete car
Original sheetmetal first repaint in 2014 factory TX9 Black car.
This car was born triple Black but I changed top and interior color to mimic my first Satellite Sebring Plus.
After the drivetrain was removed the inner front wheel wells were power washed along with rear wheel wells and bottom of car.
Factory undercoated car that I freshened up.
Front wheel wells were painted when engine compartment was painted per factory.
The trunk is so nice I didn't restore it and still has original tire jacking instruction decal.
White Canopy Vinyl Top and White Bucket seat interior.
Correct headliner from SMS seat covers from Legendary etc...
I Restored complete dash and woodgrain pieces done by GCAR
Also every emblem is NOS including the header panel emblem.
Some side moldings are NOS the rest is very nice original
The driver's side mirror is NOS also.
Door latches were restored.
Door strikers are NOS
Every bracket and pulley on engine powder coated.
Every bracket for grill and bumper powder coated.
Transmission crossmember powder coated.
Rearend housing powder coated.
K-Frame powder coated
Suspension all rebuilt and painted correct colors and factory markings that were found on disassembly reproduced.
Lower control arms Cosmoline coated.
Car was never rusted or damaged, almost a survivor when I started the process. Two broadcast sheets, fender tag, braking sheet, quality control sheet (I found under the carpet) owner's manuals, warranty card with original owners name and selling dealer in California.
Everything is matching but have original engine sitting under the bench, was running fine when removed in 2014. (Included in sale)
I built a 75 400 Stroked to 512 using 440 Source kit and also 440 Source Aluminum Stealth Heads. All components were rechecked and balanced.
TM-6 intake and Holley 750 Carburetor. Full TTI exhaust: Headers to 3" X system to super turbo mufflers and 3" tail pipes.
Extremely street-able pump gas 10.5 to1 set-up
Drives like a regular car, have taken 1-2 hour trips in it to shows etc...
Block was boiled, decked, maged ,sonic tested and bored with plates. Hydraulic Comp. Cams and adjustable Crane ductile rockers and custom Smith Bros. pushrods.
Heads were checked and springs and retainers swapped out for Edelbrock take-offs.
Original 727 was rebuilt by Mike Bonsanti of H.P. Motors.
Case was blasted with walnut shells and clear powder coated
Bolt-in sprag, red clutches, MP deep pan etc...
HEMI type convertor redone by PTC.
489 rear center section was totally rebuilt w/Eaton Tru Trac, US Gear, Timken bearings, crush sleeve eliminator and 7290 u-bolt yoke.
Axles have Timken adjustable factory style bearings.
Backing plates were stripped and coated with RPM (ECS product)
Housing powder coated and original markings reproduced.
Rally Wheels 15x 7 and Good Year Poly Glas G 60-15 and L 60-15 tires.
Brushed trim rings also.
I can go on and on for hours and have 100's of pictures before, during and after the work was done.
ONLY contact through PM if you are serious and understand what a rare and sorted out car this is. NO TRADES Cash sale ONLY. 36K
IMG_7053.JPG IMG_0724 (Large).JPG 21150344_10214277462117473_3040517524867716891_n.jpg 21192132_10214277463597510_5005652533139776407_n.jpg
*****Price lowered to 34,750*****
Put on E-Bay at lowered price 10/31/18
https://www.ebay.com/sch/i.html?_sop=12&_nkw=plymouth+satellite&_frs=1&_fosrp=1
U Tube video 10/28/18
1972 Plymouth Satellite Sebring Plus "P CODE"
One of 1076 Automatics produced according to Galen white book.
Car is very original and #'s matching except original 400 is under work bench but included with sale.
400 stroked to 512, looks stock until you see the headers and 3" exhaust!
People always ask what does Plus mean? A Satellite Sebring Plus gives you rallye dash, bucket seats,one year only molding separating body color and lower body which is then painted a beautiful Argent color, An SSP is standard with a 318 engine, 400-2bbl. is optional up to the "P" code 400 4bbl. engine which this car is. This is the Road Runner with GTX interior big power and lower insurance costs.
I restored this car to own forever so I used the best of everything, it turned out beautiful and is a really high end driver +++. I am very ****/critical of my cars and it shows. Besides being the only one of it's kind when your out and about or at a show people are always drawn to it!
This car is a pleasure to drive . Has tons of power!
Engine is a 10.5 to 1 pump gas Aluminum Head 400 stroked to 512 cubic inches .
***Original 400 included in sale.***
Original 727 Automatic 3.55 8 3/4
Rev n nator Ignition box and coil, has built-in rev. limiter
4200 miles since restore on complete car
Also every emblem is NOS including the grill emblem.
Block was boiled, decked, magged ,sonic tested and bored with plates. Hydraulic Comp. Cams and adjustable Crane ductile rockers and custom Smith Bros. pushrods.
Brushed trim rings.
****If you need to buy at a lower price point I can set you up with a restored set of Road Wheels instead of the Rallyes and Good Years.****
THESE ITEMS BELOW CAN BE PURCHASED AFTER SALE:
***** Used emblems and NOS side moldings
*****850DP Holley Carburetor
*****New date coded windshield (ECS)
*****Ultra Flo Mufflers for this exhaust set-up
****Sorry I had to use the dirty Fender Tag picture from before restoration, paint reflection doesn't allow me to get a good shot now.*****
The person that actually comes to see this car in person will buy it!!!
Come see car or send your inspection person
Beautiful restoration! I hope you get the $$$ you want for it. I purchased a 72 SSP in Feb that is a documented 65K original survivor with one repaint. 318 factory AC car, wish it was a 400 but I'll look forward to getting the engine bay to look like yours soon.
