Is this little hook under the tranny cross member for more tension on the e-brake cable?
Yes located on the tranny cross member but it's used for suspending the e brake cable and not as a tensioner. The tensioner is on the pass. side. It has a long J bolt that hooks into the uni-body frame and the J bolt goes thru a triangle shaped bracket with a nut on the other end to use for tension adjustment. The e brake cable routes thru this bracket towards the rear end. Hope that helps. I can provide pics if you need them.
