1973 Satellite door window bushing/install kit
7:45 PM
Munds Park AZ.
I am looking for the bushings that go through the bottom of the door glass that attach the window to the regulator on a 1973 Satellite. Every kit that I find online is discontinued. I purchased the glass from Classic Industries but the nylon bushings disintegrated during removal. What a pain. If anyone has a lead on where to get the bushings or complete kit I would very much appreciate it. I have noticed that a Plymouth Duster kit is still available. Does anyone know if the bushings are the same? Or anything that will work. Thanks B
Back in the day.....
we used to use rubber plugs with threaded brass inserts.
They are at Lowes in the fastener section.
Similar to a boat hull drain plug.
Not perfect but works if you need it now.
Thank you for the reply. It is not an emergency. I would like to get my wife's truck in the garage for the winter. The only way to do this is to put the Plymouth in the driveway under a cover. I would like to have the window installed for this reason. Did you try the kit for an A body?
Thanks B
