1974 Charger battery hold down bracket fender bolt: how to bolt on fender?
74ChargerSE440
3:27 PM
Netherlands
I have a battery hold down bracket as pictured, but miss a fender hole to bolt the fender bolt in? The hole in the fender is square, so I might have the wrong bracket then? Probably I need a U bolt?
A photo of the correct bracket and set up is very appreciated.
You need the battery tray which bolts onto the fender and then the hold downs go into the tray itself.
The square hole originally had a weld nut in place. If the 5/16 weld nut is dislodged, it will leave a square hole in that location.
Thanks for your message, but I am referring the red circled bolt and hole in the braked so it can be bolted onto the fender? Not?
Yeap… along wity the inner J bolt attached also to an inner fender provision, the 71/73 is the one ilustratted with the built in bracket extension to be bolted to the top of inner fender.
74s however should get a separated bracket for that same function. Earlier assemblies works the same on 74s thought.
sorry, I don’t think I have a pic to ilustrate this at this moment, but pretty sure sooner or later will get a pic to show you
Got a pic…
its a separated bracket, which allows to keep the inner fender bolt in place while removing the hold down bracket. So don’t need to remove the bolt along with the two J studs nuts to get free the battery, just the J studs nuts
Got a pic…
Ok! So just a small bracket. I assume the bolt bolts into the fender with a U-nut, because the hole in the fender is square?
So, I have the wrong battery hold down bracket then.
The only difference will be the ”wing“ extension for the fender provision. i got the same replacement hold down kit for my 74 untill I found the correct divorced bracket, then cut that wing and done.
The divorced bracket is not available as repro, but actually could be somehow “home made”.
