FOR SALE 1974 D100 Shortbed 440/727/8.75
selling my 1974 D100 Adventurer short bed truck.
this truck has a 440 engine, 727 auto trans,
factory 8 3/4 rear end, disc brakes, power steering, trans cooler, sway bar & air conditioning, sport mirrors, sport rear bumper
the engine is from a highway patrol car. has 63k miles on it, Edelbrock intake manifold, all new belts & hoses, mild cam, milled heads w/ hardened seats, 9:1 compression ratio. NOS mopar valve cover grommets, new fuel pump. 70lbs oil pressure on mechanical gauge. genuine mopar late model starter motor
New big block radiator. 3 row high effieciency core, new hoses, new fan clutch, has fan shroud (often missing)
HEI ignition module, hidden inside mopar chrome box, msd spark plug wires, msd coil
new Hedman headers & dual 2 1/4" exhaust with 20" long Dynomax super turbo mufflers.(the long ones)
transmission is a 727 with highway patrol torque converter, huge factory transmission cooler in front of radiator, driveshaft has new u joints, rear end has new pinion & axle seals.
the front suspension has all new ball joints, tie rod ends, drag link, idler arm, control arm bushings, coil springs, etc it is all MOOG made in USA parts
the rear suspension has new leaf springs, spring hangers, bushings, U bolts, hardware etc
new brake system. rebuilt booster, new master cylinder, wheel cylinders, flex hoses, rotors, drums, pads, shoes, springs everything but the steel brake lines
truck has factory cruise control. i removed it because i dont like cruise control but it is included and really easy to reinstall
New custom upholstery done at an upholstery shop (no cheesy internet kit)
New carpet kit (havent even installed it yet)
New door seals
new plastic clips on the door lock mechanisms & tailgate mechanism
new bushings on the wiper linkage
trailer hitch & wiring for lights
NOS mopar heater core
Factory dual gas tank truck. It has gas tank is under bed, it has NOS Mopar sending unit. new filler neck hoses, new vent hoses, NOS grommet on top of the tank for vent line, New vintage chrome locking gas cap. the in cab gas tank has been removed but i have it and it is included with the truck.
truck has lots of power. you can stab the gas from a stop and it will lay 97 feet of rubber with both tires.
the A/C system functions, but need charging. i havent charged it because i wanted to replace the 1 hose (45 years old original) before i had it done.
all work done on this truck has been with Made in USA or NOS factory Mopar parts (except for very very few things that i couldnt find)
no smog test required in the state of CA ever. 1974 is smog exempt
never been wrecked
tags are paid until 2020
asking $9995 or make me an offer in person (i have spent more than that just in parts on this truck, not including buying the truck, or the hours and hours of labor)
all work has been done within the last 7000 miles
also comes with
brand new carpet kit
original dash panel with wood grain (but its cut kinda ugly around the radio hole)
in cab gas tank
original green hood (rust hole in bird bath like alot of them)
the original cruise control from this truck
714-642-4643
man I wish I had the $$$
