plymouthman72
That guy sounds like an a$$hole. Build your car faster than his, and I bet he'd shut up. If that were my car, this is what I'd do: Make a sleeper car, 440 cid small block stroker, trick flow heads, a nice hydraulic roller cam and lifters, edelbrock 4 barrel intake, long tube headers, EFI throttle body system, and I'd bet you would be in the 500-600 hp range if not more. But paint the engine the same color as the original 360, and try to make it look as much as possible as a stock 360 engine. Nobody would suspect a thing unless they took a closer look. Maybe even add a gear-vendors overdrive to a beefed up 727 trans. Then I would re-do the interior to bone stock, and repaint the car it's original color, and basically make the car look like a regular 360 roadrunner. That sucker would launch so hard that NASA would be calling you for advice.
And make sure to have a rag from all the blood your coughing up due to the kidney you sold to make this happen!
