My experience with zener diodes is they burn out protecting the rest of the circuit. Usually a max voltage is used so it will burn out like a fuse. They, being diodes also protect from reverse polarity.
That is good to know. I have a couple old harddrives around where I have robbed SMD transisitors off it depending if NPN or PNP is needed. Also SMD resistors and caps.So a Zener has a 'knee' that once the current gets there it clamps the voltage. You can make a Zener by connecting the Collector to the Base of an NPN transistor, and depending on the transistor Beta a 'knee' will occur, etc.
More info than you want to know.
Try to power the circuit off of 5V and see what you get.
That is my thoughts exactly is that these chips were custom made to be a real time clock and drive a VFD before cars were controlled by a CPU.Great work. I worked from National Semiconductor from1991 to 2003. I've got no contacts there as most people I worked with have passed away or was laid off after the acquisition by Texas Instruments.
It might be a ASIC ( application specific integrated circuit). National had a good ASIC business with many automobile suppliers.
Thanks for the update and sharing your findings.
