digitaltamer1
Asking $17,500. Will consider any reasonable offer. Smog exempt clean title in hand. Cash only. Located in Poway, CA. Over the last 7,000 miles:
Mods:
Wilco rack
Knaack Box
Abus locks with Abloy cores
Two Swingcases
OEM Sport Headlamps
PIAA 510 fog lamps
Derale trans cooler
DOR steering brace
4" exhaust (muffler welds cracked)
AFE exhaust manifold
Banks fuel plate
"BHAF"
Intake horn
2.5" coil springs
Braided brake lines
Drop pitman arm (OEM included)
Delco 28si 200amp alternator
00 gauge battery cables
Glow Shift gauges
Timing at ~16°
Boost elbow
Extra parts:
4k GSK + 12 60lb valve springs
New parts:
35x13 (325/55R18) Vision Offroad Rage wheels
Borgeson high ratio gearbox, steering shaft, hoses and pump
Dynatrac ball joints
T-Style steering
Adjustable track bar and control arms
Poly bushings
Bilstein 5100 shocks
Maxx Links
Fuel lines
Tork Tek overflow valve
Hub bearings
Axle U-Joints, bearings, and seals
Calipers and brakes
Vacuum pump and lines under the truck
Throttle cable
Belt and tensioner
Grid heater relays
Parking brake cables
Mods:
Wilco rack
Knaack Box
Two Swingcases
OEM Sport Headlamps
PIAA 510 fog lamps
Derale trans cooler
DOR steering brace
Banks fuel plate
"BHAF"
Intake horn
2.5" coil springs
Braided brake lines
Glow Shift gauges
Timing at ~16°
Boost elbow
Extra parts:
New parts:
T-Style steering
Poly bushings
Maxx Links
Fuel lines
Hub bearings
Calipers and brakes
Throttle cable
Belt and tensioner
Grid heater relays
