FOUND 2 Barrel Air Cleaner
CherryBomb
1:30 AM
St.Petersburg, FL
Feedback: 4 / 0 / 0
Before I jump on eBay, I figured I would ask here. Looking for a stock air cleaner for my '66 Charger. Running a 318 Poly with a Stromberg WW carb, not sure how much that affects the fit but figured I would share. Ideally I would love one that is correct for the car, but otherwise even one that is close will do. My hope is that this is a pretty common part that some of you have sitting on a shelf collecting dust (after the very sensible upgrade to a 4bbl haha)
PM sent....I have one from a 66 Coronet off a 318 poly.
If you're running a WW make sure you're getting the correct air cleaner base. You may need the type with the built in clamp and spam can key. An air cleaner made for a Carter has different mounting hardware.
