This is the Volvo 2 speed fan with the Volvo relay and 80amp fuse. This fan uses negative power to run so if you have efi that is capable of controlling e-fan(s) your set. Or it can be used with a BMW temp switch and your golden. This fan is just like the Taurus fan (same motor) but it unbolts from the shroud unlike the Taurus fan. I can’t use this in my Dart due to not enough room (big block). Asking 120 shipped. Also local pick up is fine, 93230.
