I believe you mean the crank is cut .030" under. So chances are they cut or at the high limit. Thus tight bearing clearance.They're .3 oversized since the crank was ground that much.
Sorry, I didn't mean to confuse.I believe you mean the crank is cut .030" under. So chances are they cut or at the high limit. Thus tight bearing clearance.
Doug
The rod parts of the crank are ground .3. The main parts of the crank are only ground .1. Two different measurements on two different parts of the crank.Step back, and have your machinist explain to you, how much .3, and .1 is.
Typo? Maybe...but big difference.
I think what he's getting at is that your numbers are .3 and .1 when what you mean is .030" and .010" ... Big difference. .3 is nearly 5/16 of an inch. Using a tape measure and a feeler gauge, you'll get an ide of just how big that difference is.The rod parts of the crank are ground .3. The main parts of the crank are only ground .1. Two different measurements on two different parts of the crank.
