451Mopar
No gasket on double sided nut, just the large outer seal under the plate. You can tap the center part of the plate down with a hammer a bit from the back side if it contacts the block before pulling tight on the outer part of the plate to block gasket.I’m having the same problem with a 73 La 318 I’ve tryed twice my engine is in the car trying to prime it with cordless drill problems 1/2 qt on the floor but I do have oil pressure think there’s surpose to be a gasket on that double sided nut that holds flat plate to block the other side the filter threads on have a great holiday gonna ,try again tue
