wyrmrider
A .040 over 360 is just a stroked 340
some pay big bucks for a stroker and you already own one
put the money in the heads ( at least magnums)
YOU should not spend money on stock J or X or whatever iron heads-
(I have some with new guides and exhaust seats but I do not recommend them today unless you are doing some matching number deal)
(unless you need to buy a rotating assembly)
get pistons that will give you a tight quench at the compression you are looking for
get a cam that uses a .904 master not a chevy grind that works with the compression and heads and exhaust and intake and the rpm range you want
There are several recent series specially for MOPAR
for street I use one that's only 256 @.006 204 @.050 but has .305 lobe lift- compare that with some one size fits all chevy lobe
