Sure. Get a 3g hemi, TTI mounts and bolt them to the engine. Rubber isolators form the auto parts store or poly loc's from Shumachercreative services. Bam!!!, drop the engine on your factory k frame. Now the detail stuff. Need to use an oil pan from moroso, canton, charlies etc. along with the matching pick up tube, this pan will be a mid sump pan. Power steering or not?, power is nothing more than getting a couple of hoses made to hook up from the pump to the box, manual...no hoses, move on. Ac?, new hoses to the compressor, no ac?, no worries. Headers get from TTI, done. Now, do you want to run aftermarket efi or factory? Aftermarket, msd, fast, megasquirt, accel etc. Factory, hotwireauto.com for the harness (plug n play with 5 wires to hook up) use an 05 truck computer and they can program it for ya (basically they can set ya up to get it runnin'). Fuel....tanksinc.com for an intank pump with sump (walbro 255), corvette filter/regulator and that's done. Any small block trans of your choice...auto...904, 727, 518, 500, 545rfe, 4-5-6 spd., but for a total drop in just use a 904 or 727 auto or a factory 4 spd. and your set. Check my thread...
www.forbbodiesonly.com/moparforum/showthread.php?1618-late-model this will give ya an idea of what you can expect. Last thing, radiator...use what ya like. Oil filter adapter will need to be the 45 degree from a 4x4 truck or I think, durango. This is a part that can be had from the dealer or hotrodlane.cc they also have alot of stuff for swapping the engine. Hope this helps.
Bouchillon is really proud of the stuff....but they know their stuff.
