360/904 torque converter weights
JasonD
10:43 AM
NE TN
looking for the tc balance weight location diagram for a 360la/904. Found it for a 727, found it for the magnum. Is the location on the 727 the same? I have 2 60g weights and the means to tack them. I know they go on either side of the drain plug but I’m looking for the measurements. I know B&M makes a flex plate. The trans is already in the car, maybe the next time it’s out I’ll go the flex plate route.
Thanks, that’s the thread where I found info on 727 earlier. I need the book that info came from….lol
Seems to me Mopar performance or Direct Connection had a weight kit you could buy. It had a chart and diagram for all the converters and what weights and where they went. You might google multiple ways for instructions and get lucky.
904 and 727 would be the same. As the weight location from the C/L of the crank and location based on the crank mounting position is what balances the crank. as you have probably noticed the magnum and LA 360's use different weight.
Doug
Just to update, worked like champ. Driveline vibration is gone. I got this car from my stepfather when he passed. I’ve only had it a month or so. I think he was chasing this before he got sick as every rotating piece under the car was new.
