HP vs non???
A couple things missed. Though all you need to understand is the differences are in the parts used for the build.
FYI, just in case you don't know, the 383 is a 'low' block, but one of the best motors you can deal with.
Guts of a non are usually cast crank (though the 67 might be standard with a forged), cam, pistons, rods, heads, intake, exhaust manifolds, and so on.
The main parts said above also make the dif for an HP build, always with a forged crank. Compression is set by the particular parts used, and how it's glued together.
