cr8crshr
- 6:47 PM
- Feb 13, 2009
- Northwest Nevada
Yesterday I pulled the 383 out of my project to begin tear down and swap of components to the replacement 383 I now have. On installing the lifters every one was slightly snug except for one which would not completely seat to the cam lobe. Inspecting with my finger, there appears to be a slight and very small ridge at the bottom of the lifter bore...cam side...that is causing the lifter to not fully seat upon its respective lobe. I am wondering if after removing the lifters and the cam, can I hone this particular lifter bore without having to do all of them. When I say the other lifters are snug, they will accept the .904 MOPAR lifters but when they came out of the first engine they were slightly looser. When I rotate the cam now installed in the new motor, all the lifters ride up and down smoothly on the lobes...except the one that isn't full seated...so I know that all will work correctly, and I was able to spin the lifters with no interference when in their bores. Just this one lifter bore that needs to be given a slight hone. I am re-using the cam and lifters...after a complete inspection of the Cam and each lifter...as I only have an hour and a half total run time in the first motor and there is absolutely no adverse wear on either the Cam Lobes or the bottom of the Lifters. Cam and Lifters are by Hughes of which I have used on my past builds with the same results. Thanks in advance FBBO for any responses. Tools are always good to have so if anyone knows of a good kit to get then please advise...cr8crshr/Tuck
