4 BBL Air Cleaner base for A12 Hood ?
Gary Gaz
7:03 PM
New Zealand
Hi
I was looking for a 4 barrel carb base to fit my glass hood.
Something like the attached picture, seems were around years ago
Any ideas
I wouldn't mind one of those also. The dilemma would be - would it fit with and Indy single plane intake.
I believe you will need the top as well as bottom
because as I recall the spacing on the studs that
hold the top on are in a different location than the
6 pack top.
I have a 1969 Roadrunner Air Grabber top and bottom Air Cleaner assembly
in very nice shape = Original Paint and even the "Coyote
Duster" Decal is in nice shape on the top.
$650.00
You would have to fabricate a seal to match you hood assembly.
I have never seen a Mopar factory 4 Brl. that has that ducting.
Now I have found the base dimensions, I wonder if you could get one folded up out of metal and graft a 4BBL base to that tray then find a way to seal to Hood
Sounds like a piece of cake to me.
