Mike Szadaj
- 12:34 PM
- Jan 17, 2019
- St. Clair Shores, Mi
68 Coronet. Converting to a 4 speed. I have to buy all the bolts for flywheel, clutch, bellhousing, and starter. What was the reason for the stud and bolt configuration for the starter? For the stud to orient the starter and make it easier to get the bolt started? Can I just use 2 bolts instead? It is a smaller lightweight starter, so if there is a problem down the road, it should be easier to remove/replace compared to an OEM starter.
