BigFlo
I've got a 65 Belvedere with /6, 3 speed manual on the column. I plan to keep my front bench seat. I have a 68 383 that I want to drop in and I want to add a 4 speed. Besides putting in a new floor tunnel section in the floor, I'd like to have this as much of a bolt-on as possible because custom modifications are probably above my skill level - this is my first major restoration project. From what I've been able to research, I'll need the following major parts to make this work.
- 10.5" clutch and bellhousing with 4.35" input dia
- A833 from '66 thru '69 would be best
- 4 speed trans crossmember
- New Driveshaft - if anyone has done this swap and knows what standard driveshafts will drop in, please let me know.
- Horizontal Z-Bar - someone recommended that the heavier one used for bigblocks should be used.
Any and all advice is welcome!!
