400 carbon/soot
I’m beginning to think the gearing is not what I was told.
I have a lot of homework to do when I get home from work in a few weeks.
Thanks for the input
I will keep you posted and I am certain I will have more questions
In order to actually be spinning 6000 rpm at 90 mph you would need more than a 4.88 gear maybe a 5.13....
Jack the car up, I'm assuming the car has a sure grip? How many rotations of the driveshaft to rotate the tire one full turn?
Jack up the back. Put the trans in neutral and turn the driveshaft by hand. Count how many turns it makes for one revolution of the tire. That will get you the gear ratio.
Go back to basics on the carb tune. Float levels need to be halfway, or just below halfway up the sight glasses. Verify the proper transition slot exposure; you'll have to look under the carb for that. Once those are set don't mess with the idle speed screws anymore. Adjust the 4 mixture screws to get the best reading with a vacuum gauge and best idle quality. If this stuff is good and it still won't idle/idles too low, add initial timing, and/or bypass air through the center of the carb(if equipped). Look to start in the area of 18-22 degrees initial but watch the total. Your distributor may need a curve adjustment to keep the total in the safe range. While it's idling I like to give the pump arm a little bump and see how the engine reacts to the little squirt of extra fuel. If RPM slows down, still rich. If it speeds up, it wants a little more fuel. Ideally the RPM shouldn't change much at all with just a small quick bump of the arm. Do it for the primary and secondary. If it's still out of whack, then you'll have to look at changing pieces like the IFR's and air bleeds.
Oh...do this stuff with the engine good and hot!
I’m out working right now but I’ll be home in a few weeks. I’ll get after this and see what i have going on.
I just got back into cars over the summer so what I am reading is dusting off a lot in the back of my brain. That stuff has been on the shelf for a HOT minute but, it’s coming back.
I have the timing set at 18 right now. The guy I bought it from had it set about 30 advanced. It ran and still had more soot than I’m getting now. When I set it at 18, degrees, it really came alive.
I have a vacuum gauge on my list of things to buy.
Have you checked the choke to make sure it is opening?
Look down the throat with the engine idling. Is any extra gas dripping down in there?
