Today's saga. I removed the aluminum firewall so I could cut clearance for a real transmission fill tube and stick. I took great delight in pitching that stupid flexible dip stick set up. Also need to correct the firewall exit point for the steering column once I've repositioned the steering box. Hope to have metal for making the steering box mount by Tuesday. I've already cleaned up the left frame rail in anticipation of that.
This mess of wires was tied up on top of the steering column. Looking at the fuse panel they must have gone with one of the biggest circuit counts possible. There's a spot for cruise, power windows, A/C, and so on. I don't think any of that's appropriate for a gasser, but that's just me. Now to figure out how many of these wires are just looped up to get them out of the way vs 'sort of' hooked up to something, somehow, somewhere.
Unrelated subject: do you think a conventional mechanical fuel pump will pull enough vacuum to work with -8AN line, or should I just go with 1/2" aluminum line or assume the use of an electric mounted behind the fuel cell?
