wsutard
So now I'm not sure what kind of wedge is. I need to see if I can get the ID from it. Based on Wiki there are three kinds of 426 Wedges, 1. Standard, 2. MAX, 3. Street.
426 Wedge
Not to be confused with the 426 Hemi, the 426 cu in (7.0 L) RB was a wedge-head RB block with a 4.25 in (108 mm) bore. The 426 Wedge served as Chrysler's main performance engine until the introduction of the 426 Hemi. It was initially offered as the "non-catalogued" option S42 in Chryslers (the number of such produced is uncertain), offered with 373 or 385 bhp (278 or 287 kW) via a single 4-barrel carburetor (11.0 or 12.0:1 compression ratio, respectively), or 413 or 421 bhp (308 or 314 kW) via ram-inducted dual 4-barrel carburetors (with the same compression ratios).[6] For 1963, horsepower ratings would slightly increase (see below), and it became optional in B-bodied Dodges and Plymouths. After 1963, it would be used only in Dodges and Plymouths.[7]
The Max Wedge was a race-only version of the 426 Wedge engine offered from the factory. Known as the Super Stock Plymouth and Ramcharger Dodge, the Max Wedge featured high-flow cylinder heads developed through state-of-the-art (at the time) airflow testing.[5] They had 1⅞-inch exhaust valves, which required the cylinder bores to be notched for clearance. The blocks were a special severe-duty casting with larger oil-feed passages than other RB engines, and the blocks were stress-relieved by the factory. Induction came by means of a cross-ram intake manifold tuned for peak power above 4000 rpm and two Carter AFB-3447SA 4-barrel carburetors. The Max Wedge also included high-flow cast-iron exhaust manifolds that, on the later versions, resembled steel tube headers. The Max Wedge was factory rated at 415 or 425 bhp (309 or 317 kW) (depending on compression), and 480 lb·ft (650 N·m) at 4400 rpm.
Before the end of the 1963 model year, Chrysler introduced the Stage II Max Wedge with improved combustion chamber design and an improved camshaft. The last performance year for the Max Wedge came in 1964 with the Stage III. The factory-advertised power rating never changed despite the Stage II and III improvements.
A 426 Street Wedge block was also available in 1964 and 1965. It bears little relation to the Max Wedge except for basic architecture and dimensions. The Street Wedge was available only in B-body cars (Plymouth and Dodge) and light-duty Dodge D Series trucks. It was an increased-bore version of the standard New Yorker 413 single 4-barrel engine."
https://en.wikipedia.org/wiki/Chrysler_B_engine#426_Wedge
426 Wedge
