brian6pac
I always do the cyls first take out only what is needed and of the bore is not normal, say .0225 over then I order pistons from Ross for that size bore and they are usually spot on. Why would you go to .030, if the walls get scuffed or something happens not to bad than go .030 or .040, were as if you went .030 to start with going to .040 might not fix it than you are going .050 or .060.
