I have a .484 in my 383 with power brakes, no issues.
It idles pretty well too.
Comp 21-305-4.
2000 miles since rebuild. Great so far.
No leaks, everything checked. I have 7" vacuum at idle in gear. I tested with a vacuum gauge at the intake manifold connection point. that is with 12 degree base timing 37 total.Since that is not a "big" cam, can't see how that's the low vacuum problem. Better look for other issues.
Well good luck, no advice from me.No leaks, everything checked. I have 7" vacuum at idle in gear. I tested with a vacuum gauge at the intake manifold connection point. that is with 12 degree base timing 37 total.
Or better mr 6 pack cam..You just said you liked it way better when it was stock, I think the solution for you is a stock magnum camshaft ?
That will be interesting for you.Hey guys, looking for some advice/info. have a 440 that I have been running for years with a 484/284 cam. I love the performance but hate some other things. Looking to replace it with a cam that will retain engine vacuum for power brakes but still have some performance above stock. are there any recommendations.
history: I have worked hard to get the timing and carb set for this cam, i can drive it anywhere without issue. I recently installed a Leed vacuum pump to compensate for the power brakes. The system works great but at night with the headlights on the electrical system is always charging whenever the brakes are applied due to pump power draw. I liked this motor much better when it was stock, it was fast and fun to drive and had no external issure, now its just a pain in the butt. I am running a 2800 stall converter, 737 with 3:23 rear gears. the motor is .030 over. What is a good cam number like used in a 440HP motor that I can install to gain back my vacuum accessories off the motor and put this car more back to how its supposed to be without all the modifications.
thanks in advance.
I had a similar problem years ago. I bought a good battery and all the symptoms went away. I couldn’t believe that’s what fixed my problems. I had changed the voltage regulator the summer b4. It never helped at all. Kim451mopar thank you.
o.k. let me clarify something. the wiring is all new with electronic ignition. I was and am still running a vacuum resvoir/can with a check valve and guage. the engine will only make 8" of vacuum at idle in gear off the manifold. The can will hold 21" of vacuum but after a few pumps of the pedal in traffic its vacuum is so low i have a hard pedal and no feel with the brakes. The can will hold the 21" vacuum without bleeding out even after walking away for an hour. I installed a Leed "bandit" pump that now makes 25" vacuum, still no leaks and great breaks every time in need them. Im pulling the power source from the battery thru a keyed on relay to operate the pump. they system works very well the pump kicks on when the vacuum get below 17" and within seconds i have 25" again. its just at night with the headlights and the brakes the amp meter is always running high in the charge range until the pump gets to 25" vacuum and shuts off. I would like to put the system back to more of a stock set up running off the manifold vacuum to the can then to the booster. In order to do this I need to change the camshaft to gain vacuum. This should make the car more street friendly, tax the electrical system less.
