Hi, while getting parts together to rebuild my 68 440 HP I'm trying to decide if I should block off the exhaust crossover or not. My car is a 68 Charter RT 440 HP 4spd 3:54 Dana. Will be going all factory from front to rear. Living in the Detroit area and will plan on driving the car April +/- to October +/- time frame. I've done some research on this and still on the fence which way to go. Car when done will be for cursing enjoyment, car shows, a little traveling, and perhaps a trip or two down the 1/4 mile. I understand the cross over helps drivability a lot in the colder months. It heats the intake to heat the incoming fuel-air mixture which helps a lot in cold weather, and it heats the choke as well in the intake to heat the choke coil on the intake. I guess my concern is that is the cross over is closed off how does that affect a stock choke? I presume it will eventually heat up the intake and the choke will open. Yes? Will it just run rough until the choke opens? Any hep is appreciated.
