SOLD 440 for sale metro Detroit posting for a friend
6t4polara
10:29 PM
Mi.
Feedback: 1 / 0 / 0
440 Chrysler engine .30 over actually 446 cu.in.
9.37to 1 compression ratio
Cylinder heads ported bowls blended, 2.14" intake valves, 1.88" exhaust valves 3 angle valve job,bronze guides, Mopar roller rockers 1.5 ratio
Crane Hydraulic Roller cam, 509"- 528" lift at .050 $1004.00 of head work. Valve Springs shimmed professionally,perfectly, for cam.
Short block built professionally by S&A auto clinic Allen Park Mi. Assembled with ARP studs. Fel Pro gaskets.
Edelbrock Streetmaster dual plane intake, powder coated, with 800cfm Holley Double Pumper carb, just rebuilt last summer.(Mopar M-1 single plane Hi rise intake available).(Also powdercoated).
Milodon High Volume oil pump, 80-85psi oil pressure, 45lbs at idle, hot and running.
Aluminum High Volume water pump,
Lightweight Hi Torque starter
Holley High Volume gas fuel pump & regulator, custom bent 3/8" fuel line.
1500 miles since assembly ,no strip time and senior owned.
Hooker Headers available for B Body Mopar 62-65 for additional cost
Price is $2,850.00 carb to pan.
Reason for selling going with a Ray Barton Hemi.
Runs beautifully on premium pump gas, I built this engine to be in my car for cruising, and car shows. It had the best maintenance available. I decided, to go with a different engine configuration, for my car.
Thanks for the ad
Sent PM with contact info.
engine
Sandbagger PM sent with contact info.
Engine is out of the car make an appointment and come on by.
