Agreed. Especially if the block has a large chamfer as most factory blocks did.Needs to be slightly larger than the bore. Wont seal if it hangs inside bore.
Fel Pro 8519 is what I use on 4.375 bore. should be fine for your application.The important aspect of head gasket bore size selection tyoically osn't the block bore size but the cylinder head chamber. As a for instance 440 source stealth heads require a 4.410" minimum bore head gasket in my experience.
