- 1:37 PM
- Mar 10, 2010
- Hanover, Pennslyvania
Several good threads on here about oil pressure. This is a video of my oil pressure after changing to 10w30w (operating temp). I tried 20w50w and on cold start would be at 80 psi. It had me worried about twisting off the distributor shaft so I changed to 10w30w.
Changing the weight of your oil can help with this. Mainly being that engines can have different bearing clearances, being just rebuilt or maybe one that has high milage. Depending on your climate you could try a different weight. Other than this you would have to fine tune the oil pump valve.
In your case I think you'll be fine. I don't believe you stated what weight oil that you're useing.
