6speedGTX
451, how have your Hughes hyd. Rollers held up? I saw that they are significantly cheaper than the Comp hyd rollers and it made me wonder what kind of quality they are...
Well, a hyd roller would be a good choice for a mild camshaft in regards to risk of flat tappet failure. However, with the correct oil your chances of wiping a cam lobe are minimal during initial break-in.if im not going to a crazy wild cam , is the roller really worth doing then, this is gunna be a street motor, of course want it to go good , and sound lopey , should I stick with a flat tappet cam? just a little worried about lobe failure during break in... roller would be nice ! but?
I think a solid flat tappet cam / lifter combo can out perform a hyd roller setup....
to be honest any self respecting 500CI mopar should have a solid flat tappet or roller!!
dual pattern some where around 245-260 range and around .575-.625 lift on a 110 would be the hot ticket in a roller.
Flat tappets are scary! but if you do the right prep, run the right spring pressures, use correct oil, and have your **** straight so the motor starts up instead of turning over on the starter for two days i think your chances are pretty good. i do a little extra on my flat tappets, chamfer the top, bottom edges on the block, and also oil holes with a carbide bur. zip a ball hone through each bore. if everything is clean and dry the lifters should fall right through, if not you have a problem. good thing about solids is you can get lifters with the EDM holes. Joe Gibbs for break in and a good additive at future oil changes. if money is no object then solid roller is still the way to go.
i actually kind of tested that out. i don't have track times or dyno numbers but only a seat of the pants meter. my hyd roller specs. 246/246 .557/.557 @110 i swapped it out for a dated MP 557 solid flat tappet. 252/252 .557/.557 @110.
i run 1.6 rockers putting my lift around .600 needless to say the solid flat runs like a MFer, just can't say the same about the hyd roller. i love the idea of the hyd roller. no maint, no break in, can idle all day. Might even use it in the future, be great in a lower RPM driver. But 35 year old solid technology will drive right around the hyd roller for a FRACTION of the price.
...not all engine platforms suffer from hyd roller issues. they work well in SBlocks. i've build several small fords that went 7 grand with a properly set up hyd roller...
+1
It's more to do with all the weight that goes with the valve train in an RB Mopar. Hydraulic rollers perform GREAT in a very short deck motor like the Ford 5.0 - heck, the pushrod is only 6.2" long!
This is a great thread, thanks for sharing all the good info from guys running these cams.
Right. FYI, the pushrods in my 5.0 are 6.75".
Have any of you guys used modern valvetrain in one of these engines? How long ago were your experiences? Please tell me you didn't use 440 Source lifters w/ stockish valve springs and then conclude that it 'just can't be done'.
I just read through this,
http://www.moparmusclemagazine.com/p...ler_440_motor/
and if I'm reading it correctly, it seems the limitation is how much valve spring they dare put on it because it's a flat tappet SADI cam. They are only theorizing about collapsing a lifter. They simply did not put enough valve spring on it to control dynamics. That says nothing of the hyd roller capabilities or lack thereof.
Has anyone used a Morel w/ say, a 1.300 OD spring...160# seat/440# open? Moly or Ti retainer w/ a 1.7 rocker? This w/ ramps designed for controllable acceleration rates?
I don't know,,, I think the lifter part numbers are the same for Comp.....Ah, I see that now. Interesting.
**** lifters? I just have a hard time believing HR is not an option at 5500+, esp w/ almost 10 years advancement since that article was written.
Is there something 'special' about BBM that doesn't let it work? They seem to do fine on BBC and BBFs...maybe it's time to ditch the Mopar and build a real engine?
What Does Bushed mean? Bushed Lifter bores? What is that? thanks1. Oiling is an issue with Roller lifters. Make sure you buy lifters that have proper oiling for needle bearings. Crane Makes a roller that is designed to work with traditional blocks and does not require the block to be bushed for solid Mechanical Rollers. Hydraulic rollers are much longer and need block grinding on some stock castings. When I did my latest Hemi I used a comp Cam with their Solid Rollers that had pressure feed for the needles. I would match Rollers to Cam company if you have issues. Some people ill argue with me but I think Crane or Comp are your two top dogs. Also I used Push rods with oiling thru Push rods for extra top end oiling. I do not know if you can use Solid Roller cams with Hydraulic Roller lifters. But I know traditional blocks do need to have the lifter bores bushed with some rollers. I used an after market block and did not have to do this..
Yes, bushed lifter bores. The original lifter bores are machined and new bushings pressed into the block to create a perfect round and straight area for the lifters. It’s common for blocks to have lifter bores that are out of round or wider at the top vs the bottom.What is lifter bores Bushed mean? thanks I'm almost ready to assemble my first Hyd- roller lifter set-up. I know it's an old post but would appreciate knowing what that means. Thanks
