ZR9B
would that cam be PN# 7194 ? If so what will the lift be with the rockers you have? thanks
Started rebuilding the 440 for my 70 charger.
Block is a 1966 440 cid. Machine work = Bored 30 over, decked alighn honed, balanced 10 under forged crank
Is this a good start?
I'm personally not a big fan of the Edelbrock/Weber Carbs or their camshafts either, but love their cylinder heads & many other parts....
see above commentin blue, IMHFO it's just a set of 2 bbl carbs, running off appr. 350cfm center carb most all the time, they all need to be tuned properly for altitude, no matter what brand or style you run or where you live, jetting, quality adj. center carb metering block, power valve if you run one, fuel supply, springs in the secondaries & replace the rear metering plates with adj. types, then 30cc or 50cc accel. pump & A Pcam selection & Accel. pump discharger nozzles/squirters sizes, are all stuff that should be tuned... I run & personally like Quickfuel & ProMaxx stuff...Thank you very much tallhair for the link and the info, It has been very helpful.
I don't live at too high of altitudes, only 2500tf above sea level, in the Sierra's drive up-to about 5000ft a-s-l & back down to sea level in the valley, quite a bit {not much lately thou}, I don't have too many issues running my 6bbl on my 383/479ci Budnicks
I was going to run a holly six-pak but wasn't sure if they are any good at alititude, any thoughts?
I thought the Edelbrock aluminum six-pak intake would be a good start.
