bbcharger71
Just an update guys.... Everything is buttoned up nice! I had to swap out the input shaft and torque converter to the 300m and LS converter. I still need to use the spacers between the flex plate and converter. I also had to notch out the holes in the flex plate a tad to line it all up. I had to get a spacer for the starter for it to line up right (Quicktime sells it separate). I also cut a hole in the scatter shield to make it easier to access the converter bolts. I just drilled and tapped some holes and cut a small plate to cover the hole. I'll post pictures soon.
There was some clearance issues up top once everything was tightened down. Come to find out after pulling the trans three times, the scatter shield was not fitting flush due to the two oil plugs on the back of the block. So I just drilled two holes to allow it to fit flush. I plan on trying to finish up the plumbing and wiring this winter. Maybe I can fire this big block up in a couple of months.
