Mocajava
At one point I bought a bellhousing conversion that consisted of an aluminum ring about 1 1/2" thick that had the GM bolt pattern on tranny side and the Mopar bolt pattern on the other. Basically a pieces of crap as you had the starter on correct side for Mopar but you had to fabricate some type of shroud to encase starter nose and a cover plate to cover the GM side. I tried to make it work but didn't like the results....seemed rather weak and "K-martish". I junked it and send 4L80 off to TCI for the slab off package, bellhousing already made up plus the shifter package.... much better!
