5 speed quote for 1970 satty from Keisler
Passon makes an OD gear set that bolts right in to an 833. It's more like a 3 spd with OD (.8:1) but a cheaper alternative. Or if you don't plan on putting a ton of HP through it, look for a factory 833 OD tranny in a wrecking yard. Those used run about $250.00. If you must have a 5 spd then your choices are limited and expensive.
